Winch acting up
Winch acting up
Postby spencerdiesel » Sun Feb 21, 2016 10:26 am
It operates fine on extension, but when I go to reverse it just clicks?
Re: Winch acting up
Postby dazedandconfused » Sun Feb 21, 2016 5:04 pm
Sometimes it's just a loose wire or dirty connection. I have trouble with out winch on our trailer at work because of that. It could also be a bad solenoid. One runs out and the other runs it in.
Re: Winch acting up
Postby spencerdiesel » Sun Feb 21, 2016 5:16 pm
Thanks I'll check it out
Re: Winch acting up
Postby lz69 » Sat Mar 05, 2016 12:13 pm
what kind of winch?
lz69
Return to Electrical
