Brake controller
Brake controller
Postby mrc » Sun Mar 13, 2016 11:35 am
92 w350, would our trucks come with a factory brake controller plug or did they start in 2nd Gen? Pictures please
92 W350 flatbed with duels, club cab, stock engine, automatic (for now), 4" exhaust, air bags
mrc
Re: Brake controller
Postby Philip » Sun Mar 13, 2016 3:24 pm
1st gen didn't have brake controllers or the harness for them. That started some where in the 2nd gen year ranges.
Postby 92cummins89 » Wed Nov 07, 2018 8:54 pm
Is there a write up on how to wire one in ?
92cummins89
Postby Philip » Thu Nov 08, 2018 7:44 am
No write ups that I know of.
You will need a 20 amp power feed to the controller.
You need to run a wire to the rear of the truck for the trailer plug.
You need to tap into the output wire from the brake light switch.
Put your marker lights on a relay. Do not run the trailer markers off of the headlight switch. That burns the switch plug on our trucks.
Postby matthewh » Fri Nov 09, 2018 3:09 pm
Make sure you run a fuse or circuit breaker when pulling your power, I typically run a 10ga wire to the battery, and prefer a breaker to a fuse, but it's up to you. I also like to run my ground right to the battery as well.
Same for the wire to the rear, run 10ga, to keep the wire size the same, from the controller, as well as the trailer. You'll find the brake wire and power are 10ga, the other 2 are 12ga.
2nd gens didn't come 100% wired in till late 95. Just wired my plow truck, and while it had the relay in the underhood box, didn't have the under dash wire/plug to tap into like the later models years did. After a couple hours trying to test wires, I just ran a wire to the back and spliced into the factory plug for the brake wire, and ran power/ground off my battery. Truck is a early 95 V10
matthewh
Postby justin.loehlein » Fri Nov 09, 2018 3:38 pm
this is a pretty complete writeup and includes links to parts that would be helpful
1990 D250, 5 speed
1993 W350 waiting to be restored
justin.loehlein
