Gasser tach in a 92-93 Cummins
Postby DodgeFreak » Mon May 23, 2016 1:15 pm
So I was reading rumors you could run a gasser tach on 4cyl mode using the tach plug. You can, and I believe it is pretty close to being accurate. I'll give you the specs and you guys figure rpm and I will see if I was close. 265-75-16 rear tires, 3.55, getrag trans, running 60mph.
Re: Gasser tach in a 92-93 Cummins
Postby RumbleFish » Mon May 23, 2016 2:34 pm
I bought some adapter thingy off ebay to do this also. it didn't work, but im not convinced I have a functioning tach output signal
Postby DodgeFreak » Mon May 23, 2016 3:05 pm
I just used female ends and plugged the individual wires into the factory plug. I wish I had the actual plug but this works for now, everything for the tach is wired through the factory plug also, lights, signal wire, ground, and power. Its an Autometer 10k tach with a shift light lol. I had it for 15 years and haven't used it in anything really and decided I might as well try it.
