fuel shut off solenoid question
Postby bfeguy » Sat Jun 18, 2016 9:14 pm
Pulled up to a buddy's house today and truck didn't shut off with key. So the first thing I did was open hood and unplug the shutoff solenoid and still ran. Does that mean the solenoid is bad. Also after I shut it down with the lever I realized I had a broken motor mount and the oil pan was sitting on crossmember and turbo was on the frame. So it's down anyway.
bfeguy
Re: fuel shut off solenoid question
Postby stuffy » Sat Jun 18, 2016 10:43 pm
Solenoid is bad. Either replace it or hook a pull cable to the manual shutoff. If your pump is turned up much a new one won't last long
92 w250
Silver Bullet, pump maxed, full manual 47re, 5x18s, Hungry Diesel piston pump
stuffy
Postby bfeguy » Wed Jun 22, 2016 7:12 am
Thanks man. I am about to put in a 3200 spring and turn up the pump if it's still stock so I will probably change it then.
bfeguy
Postby Ryker Carruthers » Mon Dec 26, 2016 8:12 am
I make a brass tipped plunger that replaces the rubber tip one.
Ryker Carruthers
92 W250 g360 3.55's
Ryker Carruthers
