flickering head, tail and dash lights
Postby ggreenall90 » Thu Jul 28, 2016 12:49 pm
When my headlights are on all my lights flicker. Also my voltage gauge goes haywire when driving. Sitting still it's pretty steady but only goes up about 1/4 of the way. The more fuel you give the truck (pulling a hill) the more they flicker. Driving normal the voltage gauge ticks like a clock. Any idea as to what is wrong?
ggreenall90
Re: flickering head, tail and dash lights
Postby backfromthedead » Sun Jul 31, 2016 4:34 pm
I would check your grounds first, possibly engine vibrations are causing a loose connection to act up.
!993 W250 Auto 3.54 tuuuuurd
backfromthedead
Postby PToombs » Sun Jul 31, 2016 4:36 pm
What year is it? the early trucks had a problem getting full voltage to the regulator, causing the symptoms you describe and they actually over charge the battery. Have you checked voltage with a meter at the battery with it running?
Postby edeus » Wed Aug 03, 2016 11:35 am
Sounds like voltage regulator acting up on early models. Relaying that sob solves many problems, cannot find that topic now...
But you say voltage meter is odd, I think you have newer truck with computer hadling charging, I can not help with those.
W250 -1989
edeus
Postby DodgeFreak » Wed Aug 03, 2016 1:54 pm
my 92 with an external reg does that ticking like a clock but the idle was really low. also it over charges so I'm assuming its something to do with your reg also. Mine over charges at 18 volts I think lol.
Postby CumminsPower59 » Wed Aug 17, 2016 5:06 am
edeus wrote:Sounds like voltage regulator acting up on early models. Relaying that sob solves many problems, cannot find that topic now...
viewtopic.php?f=30&t=15828 ;)
