Replaced everything still no charge
Postby 92cummins89 » Wed Sep 21, 2016 4:08 pm
Replaced alternator, relays, cps an truck still won't charge doesn't have a voltage regulator
The gap on the cps is .050 any idea lookin at doin a one way alternator
92cummins89
Re: Replaced everything still no charge
Postby dazedandconfused » Thu Sep 22, 2016 4:35 pm
The pcm controls charging. Is anything else not working? AC and cruise work if equipped?
Postby 92cummins89 » Thu Sep 22, 2016 5:29 pm
I have all them controls pulled out right now
Would add in an external regulator fix this ?
92cummins89
Postby dazedandconfused » Thu Sep 22, 2016 6:00 pm
Yes it should
Postby 92cummins89 » Thu Sep 22, 2016 6:31 pm
Ok I have a blue an green wire comin from the alternator witch one do I use
92cummins89
Postby 92cummins89 » Mon Oct 17, 2016 7:43 pm
For anyone lookin at this post I wired in an external regulator an solved my no charging issue
I put my regulator in the middle of my engine bay an used the green an green/brown wire tht runs to the alternator instead of running new wires an then took my green/brown wire an cut it by the driver fender an ran it to an ignition hot so it turns on an off with the truck
92cummins89
