Double DIN Stereo
Double DIN Stereo
Postby toobryant » Tue Aug 01, 2017 3:10 pm
I am wanting to install a double din stereo in my 1993 W250. It is an Ext. Cab, 4X4, automatic, LE. I know it has been done but I haven't seen any detailed pictures. If anybody has pictures or could point me in the right direction I would appreciate it.
1993 W250, 4X4, Auto, Ext. Cab
toobryant
Re: Double DIN Stereo
Postby PToombs » Tue Aug 01, 2017 4:46 pm
I'm not exactly sure what double din is, but I know stereos up to '01 are plug and play. I have AM/FM/ Cassette / CD players in both my '92 and my'97.
Postby Rob_O » Tue Aug 01, 2017 8:26 pm
The factory radio is about 1.5 DIN you will need to cut the dash to fit a double din. The wiring is easy buy a harness and go.
Rob_O
Postby toobryant » Tue Aug 01, 2017 9:01 pm
I figured I would have to cut the dash a little. I just don't want it to look like a hack job. I wish I could find some decent examples of what it would look like. Thanks for the reply.
toobryant
Postby toobryant » Tue Aug 01, 2017 9:03 pm
PToombs wrote:I'm not exactly sure what double din is, but I know stereos up to '01 are plug and play. I have AM/FM/ Cassette / CD players in both my '92 and my'97.
It is the size of the opening for the radio. The radio on my truck is approximately 1.5 DIN.
toobryant
Postby BigPapa » Wed Aug 02, 2017 1:53 pm
Here's a thread I found on a Google search:
https://www.dieseltruckresource.com/for ... en-310316/
Here's how I did one in my '98:
Don't laugh too hard. It was only temporary. Got to have some TUNES!
Scott
1998.5 QCSB RWD - has '95 12V from my totaled '95, Goerend 47RE, HE351CW, DDIII injectors, 181 DV's, #10 plate, tranny temp, boost, & pyro gauges
1992 D250 ECLB Auto - dyno'd 308/630, PDR pump & POD injectors, 16cm2 E/H, BDP built A518 w/dual coolers, D70 w/LS, EGR disc brakes, dual tranny temp A-pillar, boost, pyro, and tach dash pod
1993 D150 RCSB - Building a DD/Racer Toy
BigPapa
Postby PToombs » Wed Aug 02, 2017 5:02 pm
toobryant wrote:It is the size of the opening for the radio. The radio on my truck is approximately 1.5 DIN.
Thanks for the info, I never knew that. ;)
