Fuel Gauge
Fuel Gauge
Postby 92cummins89 » Tue Dec 19, 2017 4:09 pm
My Fuel gauge isnt working i pulled the bed an unpluged it from the sending unit
not really sure where to start first
92cummins89
Re: Fuel Gauge
Postby thrashingcows » Wed Dec 20, 2017 1:49 pm
I had a fuel gauge get all twitchy....jumping all over the place. Tried cleaning the connection at the fuel tank....no change, checked the fuse panel for any blown fuses....all good, rechecked the ground on the dash, again no change, then pulled the gauge cluster and replaced the fuel gauge in the cluster....that got it working again.
thrashingcows
Re: Fuel Gauge
Postby 92cummins89 » Mon Jan 22, 2018 9:13 pm
Where did you find a new cluster gear at thinkin that’s my problem
92cummins89
Re: Fuel Gauge
Postby Richie O » Tue Jan 23, 2018 12:23 pm
The ground went on mine once. Ran a new ground from the sender to the frame. I think the fuel gauge sender is grounded somewhere in the rear light wire harness.
Re: Fuel Gauge
Postby ihredneck » Mon Feb 05, 2018 2:02 pm
Sometimes the contacts on the actual sending unit level get all cruded up over the years.
I have pulled the sending unit out of the tank and used a cloth with some brake cleaner to polish up the contacts as well as bent the contact that 'travels to help it make better connection to the 'range' contact.
1999 RCSB 1500 24v NV5600
2000 VW Jetta TDI
ihredneck
