blue sea 150
blue sea 150
Postby txs » Tue Jan 02, 2018 8:54 am
I got the 150 in hand, its a lot bigger than it looks on amazon. Was wondering if i need a slow blow fuse on the 175 amp alternator circuit or a regular fuse. And whether the mega fuse would fit on the midi block on the 150. Tired of not being able to drive on the highway cause i have zero lights. Also going to do the chryco style voltage regular as the truck hasn't been charging for years.
txs
Re: blue sea 150
Postby txs » Tue Jan 02, 2018 9:23 am
doing a little digging on amazon, guess the midi fuses are closer together on the hole centers so will try the midi fuse on the alternator.
txs
