Ignition barrel problem
Postby Jelmer » Wed Jan 31, 2018 1:36 am
I have a problem with the ignition barrel of the 93. Yesterday I wanted to start the truck so I obvious turned the key in the ignition but it felt like it slipped a tooth. Now you can get the ignition on but you can't turn it enough to get to the "start" position. Also, now you can pull the key in a different position than originaly on the position with the little tab on the column covers.
Anyone have an idea?
Greetings from the Netherlands where there are only 2 or 3 1stgens!
93 D250 Cummins, G360, 4" stainless exhaust, BHAF, DennyT stage 2 pin, 3200rpm governor spring, 12cm housing, rest stock.
03 VW Bora 1.6
83 Datsun Laurel 4.5 32v V8
84 Nissan Patrol 2.8i
Jelmer
Re: Ignition barrel problem
Postby PToombs » Wed Jan 31, 2018 5:16 pm
Sounds like it wore out and skipped inside. It's been a while since I played with one but I think a new switch is in your future.
Postby Jelmer » Thu Feb 01, 2018 12:30 am
This part?:
http://www.rockauto.com/en/moreinfo.php ... 18&jsn=445
Would be nice to keep the current key, it still has a matching set for the doors and ignition.
03 VW Bora 1.6
Jelmer
Postby PToombs » Thu Feb 01, 2018 5:36 pm
After looking at that, maybe not the switch but where the key cylinder meets the switch. I think you need to take it apart and look at it.
Postby Black93 » Thu Feb 01, 2018 7:14 pm
When mine did that, the end of the barrel broke. Like pete said just pull it apart and check it.
Black93
Postby Jelmer » Fri Feb 02, 2018 6:04 am
Thanks guys! I will take a look at it this weekend.
03 VW Bora 1.6
Jelmer
Postby Jelmer » Mon Feb 05, 2018 1:32 am
I had a look at it real quick but I didn't have the torx bit with a hole in it so I need to get that first.
But I noticed that the bottom cover had some ripples in them from the ignition wires that run there. Those must have been very hot to make the plastic ripple!
Also, the wipers and clock didn't work but when I hit the ignition switch they started working.
03 VW Bora 1.6
Jelmer
Postby Jelmer » Mon Feb 12, 2018 1:37 am
Black93 nails it! The barrel end has a piece broken of. So I need a new barrel too. The switch did cure the problem with the not working wipers and clock. The connector on it also needs attention because some wires are burn't. The big red feed wire was a bit loose so I crushed the socket a bit so that it is tight again.
03 VW Bora 1.6
Jelmer
