what's this to and where does it connect
Postby imtonydillard » Sun Aug 12, 2018 5:45 pm
Re 1990 D150 3.9L
This harness is under the dash on the driver side. The wire colors are: Blue white, Yellow red, White green and Brown red.
Any idea what they go to and where the receiving connector might be located?
http://s58.photobucket.com/user/imtonydillard/media/wire_zpscmlk38rt.jpg.html?sort=3&o=0
imtonydillard
Re: what's this to and where does it connect
Postby PToombs » Mon Aug 13, 2018 4:34 pm
Here it is,
Postby imtonydillard » Mon Aug 13, 2018 6:02 pm
Pete - I don't understand your response.
imtonydillard
Postby PToombs » Tue Aug 14, 2018 5:19 pm
I copied the tag and posted your pic right on the page so it can be seen without going off site.
Postby imtonydillard » Mon Aug 20, 2018 12:26 pm
thx
imtonydillard
Postby thrashingcows » Sat Aug 25, 2018 12:29 pm
I don't know for sure but wonder if it is for a factory tach?
thrashingcows
Postby PToombs » Sat Aug 25, 2018 4:18 pm
Factory tach plug is gray and flat, not squared.
I just went and looked at my truck and thought I didn't have it, and realized I do, it's fastened to the hood handle bracket. I think it's the diagnostic plug for the ABS system.
Postby cougar » Sun Aug 26, 2018 10:22 am
According to my FSM, it says "RWAL Test Connector (In Plant Use Only).
01 2500 "the work truck".
cougar
Postby PToombs » Sun Aug 26, 2018 4:53 pm
Yup, thought it was after I looked at my truck.
I never bothered looking in the FSM because I wasn't sure where to look to find a random connector under the dash. ;)
Postby Lazyjoe1 » Thu Jan 18, 2024 6:04 am
Do they still make an aftermarket tach that will plug into my factory 93 harness? Thanks in advance. Joe
1993 W350.
1995 Ram 2500.
Lazyjoe1
Postby Richie O » Sun Feb 11, 2024 10:01 pm
Lazyjoe1 wrote:Do they still make an aftermarket tach that will plug into my factory 93 harness? Thanks in advance. Joe
Isspro did. They still might.
Users browsing this forum: No registered users and 65 guests
