Starter is stuck
Starter is stuck
Postby 92cummins89 » Sat Nov 24, 2018 2:30 pm
Changing the starter on my 92 Cummins an got all the bolts out an wires disconnected starter is lose but won’t come out any ideas?
92cummins89
Re: Starter is stuck
Postby 92cummins89 » Sun Nov 25, 2018 11:29 am
Anyone?
92cummins89
Postby PToombs » Sun Nov 25, 2018 5:30 pm
It should fall right out if all the bolts are out. Maybe the nosecone is broken and jammed in there?
Is it stuck on the breather tube? I remember on both my trucks the tube goes behind the starter and is jammed in there. It may be binding it somehow?
Postby monoblock » Tue Feb 26, 2019 9:28 am
Is it necessary to remove it ? Suggest a quick check of the solenoid contacts - known weak point
Also consider installing a relay. See my Post for links.
viewtopic.php?f=30&t=17858
Let us know ?
monoblock
