Where does this go? Alternator resistor
Postby Hatya » Sat Dec 08, 2018 8:00 am
I am doing a one wire alternator install on my 93 d350 and it came with this resistor.
https://www.napaonline.com/en/p/ECHAD1214
I guess I’ve forgot to much In my old age, where does this go and why?
Hatya
Re: Where does this go? Alternator resistor
Postby cougar » Sat Dec 08, 2018 9:28 am
Last time I saw something like that was on an old point type voltage regulator.
01 2500 "the work truck".
cougar
Postby PToombs » Sat Dec 08, 2018 2:46 pm
I've never heard of putting a resistor in with a 1 wire alternator. I would contact whoever you got it from and ask them.
Postby Richie O » Tue Dec 11, 2018 8:06 pm
PToombs wrote:I've never heard of putting a resistor in with a 1 wire alternator. I would contact whoever you got it from and ask them.
The last one I did that required a resistor was putting a 3 wire ac delco on my farmall tractor. I thought the same Pete, the single wires went direct to the battery. Maybe the resistor keeps it from draining? I think a resistor only allows voltage or current to go in one direction? On edit, I think its a diode that does that, I have not hit the books for a while on electronics.
Postby PToombs » Wed Dec 12, 2018 6:16 pm
Richie, a resistor reduces voltage, and a diode lets current go only 1 way. Good save! ;)
Postby Richie O » Thu Dec 13, 2018 11:08 am
PToombs wrote:Richie, a resistor reduces voltage, and a diode lets current go only 1 way. Good save! ;)
Yup I knew that, but had to catch myself. :roll: I guess I put my fingers in gear before my brain.
