power supply
power supply
Postby jituchnfd45321 » Fri Feb 22, 2019 4:30 am
How to protect the power supply against over voltages or surge voltages?
jituchnfd45321
Re: power supply
Postby Philip » Fri Feb 22, 2019 6:47 am
By power supply I have to assume you mean the power train control module (PCM).
Keep all ground connections clean and tight. The battery is your surge protector. Bad grounds is what would cause surges when you turn items on.
