91 W350 speedo issue.
Postby jethro75 » Tue Apr 16, 2019 8:27 am
Good morning all.
I have a 91 W350 my speedometer when the key is off is at zero as soon as I turn the key on it pegs out. Where can i start is it a speedo problem or sensor issue or possi let wiring issue? I'm pretty limited on my electric diagnostic ability. Lol thank you for the help
jethro75
Re: 91 W350 speedo issue.
Postby thrashingcows » Sun Apr 21, 2019 1:43 pm
I would unplug the VSS sensor off the trans/transfer case and see if the problem persists. If it does then it is most likely in the wiring.
thrashingcows
