Brake lights only work with hazards on
Postby spencerdiesel » Wed Jun 30, 2021 5:48 pm
So I was hoping replacing the multi function switch would solve this dilema, but no. Brake lights only function when the hazard button is on. And when the hazard button is on, the hazards don’t work.
Any insight to the next step is greatly appreciated, I’m not too savvy with electrical.
Thanks!
H1C/18
Muffler delete
spencerdiesel
Re: Brake lights only work with hazards on
Postby PToombs » Sun Jul 04, 2021 4:52 pm
Have you tried replacing the flasher? Just swap it with the regular signal flasher.
I would have bet on the multifunction switch too, the brake lights go thru it.
Postby spencerdiesel » Fri Aug 27, 2021 5:52 pm
No I haven’t done anything with the flashers, what do I do to go about locating that :D
Thank ya Ptoombs
H1C/18
Muffler delete
spencerdiesel
Postby PToombs » Sun Aug 29, 2021 12:56 pm
Sorry Spence, I don't get on as often as I used to. Both flashers are in the fuse box, cylinder shaped things.
Postby spencerdiesel » Tue Aug 31, 2021 11:10 am
I appreciate it Pete! Unfortunately I’m not on much either, the ole girl still gets 21 or so mpg and hasn’t stranded me so far in 8 years and 110k though :)
H1C/18
Muffler delete
spencerdiesel
