Please Help!!!! confusion info for starter relay
Postby mattme » Mon Feb 11, 2008 10:32 am
So I am down to wiring and other stuff on the 6bt swap and I am getting confusing info regarding the starter relay. I downloaded the 91.5 diagrams and compared them to my truck (1989) and found a discrepence.
On the starter relay there is 2 yellow wires, one goes to the engine controller and I do not know where the other goes but the wiring diamgrams show that wire as only one wire.
Could someone look at there truck and see what the yellow wire does? It is a hot wire, if so hot in start, start/run? Or is it a ground wire?
The donor truck wa an 89 2wd auto truck.
The connector is shown as
http://dens-site.net/Dodge_CTD/1991.5-W ... Scan06.jpg
The only difference is that mine has only one brown/yellow wire and 2 yellow wires.
Thanks,
Matt
mattme
Re: Please Help!!!! confusion info for starter relay
Postby flashgordon » Mon Feb 11, 2008 12:57 pm
mattme wrote:So I am down to wiring and other stuff on the 6bt swap and I am getting confusing info regarding the starter relay. I downloaded the 91.5 diagrams and compared them to my truck (1989) and found a discrepence.
Thanks,
Matt
The positive bat cable has a 2 prong connector that the starter wire go's thru
I don't thing it go the the computer but the key switch its self and then back thru the 2nt post of the connector on it way down to the starter. It is taped to the main power cable going to the start.(You are taking about the signal side of the start right?)
Flash
flashgordon
Postby mattme » Mon Feb 11, 2008 2:01 pm
Flash,
Thanks for the info, I see the wire taped to the main starter lead. I figured that went from the relay to the soleniod. I got that side figured out. I am interested in the yellow wire on the starter relay. I believe the yellow wire is either the power signal wire or the ground for the relay.
The problem is that the yellow wire also runs to the engine controller.
Thanks,
Matt
mattme
Postby PToombs » Mon Feb 11, 2008 3:10 pm
In my 93 FSM, 1 wire comes from the ignition switch, 1 to the PCM and the neutral (or clutch) switch. Same as the one you linked to. Yellow from switch, brown / yellow stripe to PCM and neutral switch. I think the wire goes to the pcm to tell the computer whats going on.
If you are wireing from scratch, it doesn't matter which side of the relay is + or -.
Users browsing this forum: No registered users and 69 guests
