Intermitant wipers no longer intermittent?
Postby gear jammer 91" » Tue Feb 12, 2008 5:55 pm
I went to turn my wipers on today and found out that my intermittent now only has two speeds, fast and faster? :? Is their a box or relay of some sort that controls the wipers?, or is it all in the end of the turn signal? I know I should quit being cheap and just go buy a chilton or haynes cause it would probably tell me but this site is so much better than any book. ;)
01 LB7
gear jammer 91"
Postby wannadiesel » Wed Feb 13, 2008 5:12 pm
There's a module under the dash that Dodge will be happy to sell you.
Best dyno: 408/844
wannadiesel
diesel guru
Postby PToombs » Wed Feb 13, 2008 6:37 pm
And don't waste your money on a Chilton or a Haynes. Buy the factory manual. Geno's garage, $99, or e-bay.
Postby gear jammer 91" » Wed Feb 13, 2008 7:02 pm
I was informed that the intermittent control is in the noisy buzzer under the dash, so I unplugged it to see if it did anything. Now my wipers are intermittent again and there is no more annoying buzzer. 8) I don't understand why and I don't even care so long as my wipers wok right. :lol:
01 LB7
gear jammer 91"
Postby cummins king » Wed Feb 13, 2008 7:07 pm
does the horn still work :lol: :jumpsmile:
93 4X4 auto
cummins king
Postby gear jammer 91" » Thu Feb 14, 2008 5:05 pm
I think the horn is the only thing I didn't check. If it's broke I still got the finger :)
01 LB7
gear jammer 91"
Postby PToombs » Thu Feb 14, 2008 5:13 pm
I think you used the wrong smilie, I think this is the one you wanted, :finger:
:lol: :lol:
Postby gear jammer 91" » Fri Feb 15, 2008 4:35 pm
If I had known where to find that smilie I sure as hell woulda used it. And I checked the horn still works!
01 LB7
gear jammer 91"
Postby PToombs » Fri Feb 15, 2008 5:53 pm
Where it says "view more emoticons" click that.
Trust me, you'll like it! :hs:
