Wiring Diagram '93 CTD (intercooled)
Postby jimmyt83 » Wed Apr 09, 2008 9:10 pm
I need the wiring diagrams for the engine I have out of a '93 IC CTD...anyone know where I can find some?
Thanks.
Jimmy
jimmyt83
Postby dpuckett » Thu Apr 17, 2008 7:00 pm
Factory Service Manual has them.
What are you needing to wire up? All you really need is power to the injector pump to run, and grid heaters if you opt to keep them. Gauges, too, I guess.
Daniel
Postby Diesel Nut » Thu Apr 17, 2008 7:57 pm
Gauges aren't all that hard. Depends on the conversion. If you go for all aftermarket gauges you can replace the stock senders with the Aftermarket ones (Autometer, Di Pricol, Isspro).
Now, on the other hand, you can take the stock senders for the conversion truck's engine and mount them to the donor motor and the factory gauges will work.
What are you converting?
2006 Dodge 2500 4x4
1991.5 250 Reg cab - Parts Runner
1990 350 Reg cab - Wants to be fast
www.dieselnut.com
Amsoil Dealer
Diesel Nut
Users browsing this forum: No registered users and 66 guests
