truck wont start?
truck wont start?
Postby 93ctd » Sat Apr 19, 2008 7:32 pm
i went out to start my truck and the battery was dead.hooked it up to my suburban to jump it. hooked up the jumper cables and let it jump for about 15- 20 minutes. tryed when i first hooked it up and it didnt do nothing. went out and tryed again. this time it turned over twice went click click and heard a pop. now i have nothing. my wait to start light wont come on and it seems i have no power to my ignition.can anybody help?
first gen dodge's are the best looking trucks made
93ctd
Re: truck wont start?
Postby Ace » Sun Apr 20, 2008 6:55 am
93ctd wrote:...click click and heard a pop.
That's disturbing. Fuses and fusible links are always a good place to start when something like that happens.
Ace
Postby 93ctd » Sun Apr 20, 2008 3:10 pm
i checked out fuses under the dash and the links on the drivers fender every checks out fine. could it have fried the selenoid on the starter?
93ctd
Postby 93ctd » Mon Apr 21, 2008 9:35 pm
35 looks and nobody has an idea?i was told you guys were good :roll: :D
93ctd
Welllllll.....
Postby Ace » Tue Apr 22, 2008 5:16 am
I suppose the next thing to do might be test the starter itself. Have you jumped 12v straight to the solenoid?
Ace
Postby PToombs » Tue Apr 22, 2008 6:25 pm
93ctd wrote:i was told you guys were good :roll: :D
Good for what? :scratch:
:pottytrain:
If you don't have power to the ignition, it's gotta be a fusible link. No dash lights, radio, anything? Tell us what you do and don't have specifically, and we can look in the FSM and tell you which one to check.
Postby 93ctd » Tue Apr 22, 2008 7:25 pm
i do have head lights, hazzards fan motor ; but no blinkers stereo or dash lights mabey ill have to go double check the fuseable links again? i really hate electrical but want to learn
93ctd
Postby PToombs » Wed Apr 23, 2008 5:32 pm
Do the wipers work? If not, it's a fusible link for sure.
The fan works? :shock: That runs off the same link....... Check fuses with a test light, see if all have power. Some have constant, some keyed.
Man, this is strange. I reread the whole thread, and stuff gets power from 2 different sources, but you get power on some and not others.
Did you try cleaning the battery terminals good? and any plugs in the large red wires to the fender stuff? Try that next, it sounds like a bad connection more than a bad link.
Good Luck!
Suggestion
Postby opofus » Sat May 03, 2008 7:38 am
I had that happen on a honda accord. What I did was hook the cables up backwards, and I fried the battery, the aleternator, and the main fuse in the vehicle. After I replaced the main fuse and the battery, it started and ran. I found out about the alternator a few weeks later when the new battery ran down while I was driving.
opofus
Just a little more
Postby opofus » Sat May 03, 2008 7:40 am
It would not do anything until I changed out the battery, the battery was grounding itself out.
opofus
Postby PToombs » Sat May 03, 2008 4:25 pm
93, get it figured out yet?
Postby 93ctd » Sun May 04, 2008 12:51 pm
not yet its been raining so i havent went out to look but its starting to get nice outside so im fixin to go out before it starts raining again
93ctd
Postby BEARKILLER » Tue May 06, 2008 10:22 pm
Time for a new battery.
#4 = 1991 D-350 LE Getrag
BEARKILLER
