Isspro 6591 Tach install ???
Postby rbrettctd » Fri Apr 25, 2008 5:20 pm
How do I wire this in? Is there a module/sensor for a pickup on the alt. or how does that work? Its an early 91 so theres no tach pickup already on the truck. Thanks.
Randy
rbrettctd
Postby gear jammer 91" » Fri May 02, 2008 5:28 pm
I haven't done it but I believe there is some info on how to hook a tach up to your alternator in the sticky over at http://www.dieseltruckresource.com/
or maybe on http://www.cumminsforum.com/ I might be wrong but I'm pretty sure I saw it in one if there sticky's. Hope that helps.
01 LB7
gear jammer 91"
Postby rbrettctd » Sat May 03, 2008 9:00 am
Im on both forums, big time poster over on DTR. The tach install in the sticky is for the 92-93. I finally got an answer over there a few days ago. Thanks though.
Randy
rbrettctd
