Factory Tach
Factory Tach
Postby peobryant » Tue Jul 22, 2008 4:15 pm
I may have access to a factory tach from a '93 D350 and I was wondering if I could use it in my truck. If so, what would I need?
Thanks.
Postby SNOOT » Tue Jul 22, 2008 4:31 pm
You should have everything you need in your 93 its under the dash around the steering column.
If you get it and it is factory you will have several jealous people on the board.
1993 W350
SNOOT
Postby PToombs » Tue Jul 22, 2008 6:00 pm
He said the tach is from a 93, his truck is a 91. If the truck is I/C'd it should have the plug. I'm not positive because I think i read someplace that this was hit and miss on the 91 trucks with intercoolers. Look for the plug 1st, and go from there.
Or get it and sell it to the blood thirsty bunch on here. ;)
Postby 2muchtq » Tue Jul 22, 2008 8:25 pm
and to think I GAVE one of these to my uncle......
Thats OK. I dont plan on stopping @ 3K rpms.
2muchtq
Postby Philip » Tue Jul 22, 2008 8:44 pm
The 91.5's don't have a crank position sensor. That is one of the differences between it and a 92. That 93 tach won't work. Sorry to say.
But to be sure look at the crank damper. At the 11:00 position is where the CPS should be mounted if it has one.
Postby peobryant » Wed Jul 23, 2008 11:31 am
So is there any way possible to get this to work on my truck?
Postby Begle1 » Wed Jul 23, 2008 12:50 pm
Factory tachs only go up to 3000 RPMs? That sucks.
RS8912
Postby Ace » Wed Jul 23, 2008 2:22 pm
You can get an ISSPRO crank sensor here:
http://www.egauges.com/vdo_send.asp?Sen ... ic_Sensors
Part # RS8912. That's what I used for my ISSPRO tach. Should work for any gauge that uses a 2x electric tach signal.
Ace
Postby dieseltrain » Wed Jul 23, 2008 5:51 pm
my truck has the factory tach. it is a 4k rpm tach, not a 3k, and shows red 2800 thru 4k. the option isn't listed on my window sticker, must've been added at the dealer, will have to ask p.o. as i am the second owner. it does have a crank sensor at about 1130ish to the damper.
w250 518 auto, honed injectors, otherwise stock for now.
dieseltrain
Postby Richie O » Wed Jul 23, 2008 6:12 pm
Here is my isspro p/u
and my 4 k tach
Postby Ace » Thu Jul 24, 2008 5:57 am
That's the exact same stuff I have. Found the tach on eBay for $10. Then had to spend $50 (at the time) on the sensor kit, cause the 91.5 had no crank sensor.
Ace
Postby peobryant » Sun Jul 27, 2008 11:09 pm
So if I get the crank sensor, the tach should work right?
