How exactly do I gut the shutdown solenoid?
Postby peytonmaterne » Wed Aug 13, 2008 6:53 am
There is a spring, sleeve and an o-ring in there. Everything comes out, right?
91.5, D250, getrag
91.5, D250, auto
84, D150 with 90 dodge/cummins drivetrain
peytonmaterne
Postby PToombs » Wed Aug 13, 2008 5:40 pm
Spring and plunger come out. O-ring stays. That's the seal to keep fuel inside. ;)
Postby railhor5.9 » Thu Aug 28, 2008 7:43 am
wat does this do any power gains or wat.... kinda new to the ve
1993 d250,single cab short bed, sbc, 175hp p-pumped,4kgsk,370's, fass 150. hx35
1997 2500 4x4 , 913,191's,3kgsk,5x16, 3rd gen dubs.
railhor5.9
Postby PToombs » Thu Aug 28, 2008 2:25 pm
Not much, if any. What happens is if you start pushing big fuel, you chip the rubber tip off the plunger. Most guys then pull the guts and use a cable to the lever on the side.
The other thing is, the solenoid goes bad, so you pull the guts and go cable.
