Temperature Gauge Problem
Postby Callan » Sat Aug 23, 2008 5:20 am
Now when i'm driving normaly the temp gauge will sit at the line just below half, slowly climb to the line above half then in 2 seconds fall down to the line below half again and repeat. I'm starting to think its either a bad ground somewhere or the sender unit? Any ideas? i'm thinking of saying screw it and get some autometer mechanical gauges that i can trust.. lol
thanks
93 W250 LE, ext. cab, auto, 4x4, 4 inch straight pipe, 3200 spring, pump turned up, POD's, 14cm turbo housing, 2 inch lift, 33" BFG's, Eagle alloy wheels, Arizona truck.
Callan
Postby GO OVRIT » Sat Aug 23, 2008 6:00 am
A bad ground will cause the temp and oil pressure gauges to read high. I've had to fix the ground on th raiator support by the battery on a couple trucks.
GO OVRIT
Postby Ace » Sat Aug 23, 2008 6:05 am
Mine did that for a couple days until it purged the air out of the system after I replaced the heater hoses.
How's the antifreeze level look? I'd suspect water level and thermostat-related issues.
Ace
Postby Callan » Sat Aug 23, 2008 1:32 pm
I flushed the rad after I got the truck and all the levels see good. What is the best way to purge the air out?
Its been wagile since I flushed it. Would the air not work itself out over time?
Thanks
Callan
Postby 1991cummins » Sat Aug 23, 2008 8:19 pm
yah it should work it self out... no problem... sounds like a thermostat problem, for sure, its gettin too hot, and then letting in a bunch and cooling and then starting over...
had the same problem on mine towing one time... i didnt like it :mad: lol
1991cummins
Postby Callan » Sat Aug 23, 2008 9:16 pm
Yeah I don't like it either. Maybe I'll change that thermostat see if that works
Callan
Postby dpuckett » Sun Aug 24, 2008 6:59 pm
THe swinging of the temp gauge needle is not unusual. Not right, but I've had some do that in the past.
Daniel
Postby rbrettctd » Tue Aug 26, 2008 5:07 pm
Dont worry too much over it. I changed the thermostat 3 times, new hoses, radiator flush.....finally wised up and put a aftermarket water temp gauge on it....wouldnt you know it stays right around 180 while the stocker bounces off my doors.
Randy
rbrettctd
Postby Callan » Thu Aug 28, 2008 3:20 pm
well i do feel better that i am not the only one with this problem! aftermarket gauges are definitely on their way that is for sure. Then i can have some peace of mind and actually know what the temp is! not just the line just over half or something.. lol
Callan
