dash lights
dash lights
Postby nojackwayne » Sun Sep 07, 2008 9:25 pm
alright, the dash lights for my guages quit. when you pull the park lights on, they work, and the headlights work too. so does the interior light when you twist the knob. And no, I don't have the dash lights dimmed right down with the switch!lol Ichecked all my fuses and they are good.
Any ideas?
The only light that comes on when the headlights are on is the high/low beam indicator.
92 W250 IC reg auto. H1C w/16cm, boost/pyro/fp, 366spring, DennyT stg II, pump tweaks, k&n, custom bumper, custom dp w/4" exhuast
01 C&C 3500 4x4 man. stock for now
08 C&C 5500 4x4 auto. egr&dpf fell off
nojackwayne
Postby RumbleFish » Mon Sep 08, 2008 1:07 pm
do your taillights work? check for a blown fuse. otherwise i might try a new light switch.
Postby GO OVRIT » Mon Sep 08, 2008 8:46 pm
Are you running any additional lights off the headlight switch? They can barely handle the stock load. Probably going to need a switch.
GO OVRIT
Postby Billy Boy » Sun Sep 13, 2009 7:43 pm
Any resolution to this problem? My dash lights won't come on anymore (they arent dimmed!), but the headlights, cab lights and taillights all work still...but no dash lights!
1989 Dodge D350 Dually, Non I/C
Billy Boy
Postby cougar » Mon Sep 14, 2009 7:37 am
Check fuse 4 and 14, if they are both good see if you get a changing voltage at fuse 14 to ground when you turn the dimmer. If you do not, it is the rheostat on the headlight switch.
01 2500 "the work truck".
cougar
Postby Billy Boy » Mon Sep 14, 2009 5:55 pm
Great, I'll see what happens! Thanks for the info.
Billy Boy
