brake switch
brake switch
Postby 1991cummins » Wed Oct 15, 2008 8:27 pm
does anyone know if the break light switch there on the pedal is on the ground side or the hot side...
my break lights are stuck on, and i am just brainstorming as what could be the problem.
i would assume it was the switch, but i tried to remove the fuse so that it wouldnt run my battery down and they still stayed on... so i was thinking that maybe i spliced into it and made it hot... but that could only happen if it was a hot side switch...
thanks,
Derek
1991cummins
Postby Begle1 » Wed Oct 15, 2008 10:08 pm
I don't know if it's ground side. I'll bet it is, since that's how Chysler likes to make things.
I had mine stick on once; the brake light switch that rides against the brake pedal slipped down. I just had to push the switch back up, so that it was making contact, and tie-wrap it in place. It's worked fine since.
Postby 1991cummins » Thu Oct 16, 2008 7:12 am
thanks begle
well i can push the button in by hand and its still stuck on. so its either that switch is out, or the switch is before the light and i wired it always hot...
idk, if anyone anything about that switch it would be great...
1991cummins
Postby nooblet » Thu Oct 16, 2008 2:26 pm
That brake pedal switch has gone out twice on me, both times the brake lights get stuck on. I'm not saying that is your problem, but its a possibility for sure.
What happened on mine is that they got pushed down and stuck. I could pop the plunger back out and it would work for about a day, then it would stick closed again.
Chris
nooblet
