headlight switch, marker lights, and me...
Postby RumbleFish » Wed Nov 19, 2008 7:49 pm
i think i found the pigtail, ill know for sure when it comes in tomorrow. thanks for the offer though, ill let you know if i need it.
Postby 1991cummins » Wed Nov 19, 2008 8:01 pm
i had the exact same problem except it was just a blown fuse with me... every time i pull the mechanical arm out and put it back in the fuse blows... so if you bypassed your fuse box i bet that was the only problem... cause the exact same thing happened...
1991cummins
Postby Philip » Sat Nov 29, 2008 8:07 pm
How you getting along with it Jeff?
I am back off vacation now.
Postby RumbleFish » Sat Nov 29, 2008 9:28 pm
i got the pigtail, but havent changed it yet. been busy with the holidays and all that jazz. as much as i would have like to been in the garage, the wife thought thanksgiving was more important :roll:
Postby PToombs » Sun Nov 30, 2008 2:06 pm
Women! They just don't understand! :roll:
