ok boys...
my speedo has worked great for 260k miles. about a month ago it died on me... just looked down one day while driving and it didnt read anything. so i checked the easy stuff and said to hell with it for now
i just now started to poke around, pulled the sending unit out of the tranny and the sending unit was bad, didnt have any resistance across the two poles and put out nothing when spun by a drill... so i got a new one thinking it would be a quick fix, with no luck... the new one had resistance and put something out when on a drill... but nothing when connected to the truck,
so therefore two problems arose at the same time... i also hand tested the sensor and it was good... so the problem has to be in the wiring or the guage... i followed the wire and it seems run fine, no loose connections jump out at me...
any advice, i heard those gears in the gauges go bad with time... possible?
any help is great,
Derek
and sorry about the novel, i seem to do that sometimes
