How to dim A pillar gauges?????
Postby big specht » Sat Nov 08, 2008 9:09 pm
I have some autometer gauges munted on the "A" pillar that blind me they are wired into the dimmer switch but when I try to dim them down they don't the dash lights will go out before they will dim down low enough what is every body else doing????
I WANT YOUR ATC'S
big specht
Postby gear jammer 91" » Sat Nov 08, 2008 10:04 pm
I would guess that you hooked your gauge light's up to the wrong wire on the dimmer. I have had issue's finding the right wire before in a couple trucks. What I did to find the right wire this time was to locate a hot wire on the dimmer switch with my test light, and then dim the lights, if the test light dims you found the right wire, if not try another.
01 LB7
gear jammer 91"
Postby big specht » Sun Nov 09, 2008 6:19 pm
Yea I did that that are still to bright
I WANT YOUR ATC'S
big specht
Postby KTA » Mon Nov 10, 2008 3:25 pm
I sprayed a little coat of green paint over the bulbs on my isspros and they are perfect. I like the green hue too. :lol:
Postby Richie O » Mon Nov 10, 2008 5:31 pm
I put the red slip on covers on the bulbs. Does not blind me but I have not run them with just the bare bulbs. I tapped into the wire that goes to the heater face light.
Postby IRoss » Wed Nov 19, 2008 4:51 pm
There is a 5A fuse on the panel that is fed from the dimmer, thats what I feed my gauge lights off..after gauge #5 I put in a 7.5A
91.5IC 4x4 5spd extra springs
valet, 190s, ,18cm, 4"ëxh.
H4 conversion w/relays
rwal mia w/prop. valve
IRoss
Postby TWorline » Wed Nov 19, 2008 5:01 pm
Does your gauges have LED bulbs for illumination? If you have LED lights they will not dim with the dimmer, you will have to buy a special dimmer just for them.
Tim Worline
http://www.CoolerTubz.com/
TWorline
