So I got a 2000 watt inverter, which comes out to around 170 amps, which comes out to at least 2 gauge at 20 feet.
Think that much current is safe to ground to the frame.
Or do I mount a second battery in the toolbox or behind the seat, only run a couple feet of wire between the battery and the inverter, then run smaller wire to the battery for sake of charging? If I do that I gotta buy another $100 Optima, which is almost cheaper (and almost lighter) than buying 40 feet of 2 gauge.
Hmmm...
