RSWORDS wrote:Driving down the road all of a sudden EVERYTHING electrical will stop working for about half a second. Just enough to flick the lights and restart the radio. I though maybe it was a battery cable but they both check out fine with testing (voltage drop test). Then I checked the battery, test fine under load. BUT when I start the truck the tester is showing 15.5V and whne I go to load test it it drops back to 12V... Regulator gone bad?
I hate electrical.......
IRoss wrote:If it happens over, say maybe a slight bump, check your battery hold-down....
PToombs wrote:Permanent uncurable electrical problems or a Dodge?
Bobby, after reading back thru this thread, I'm surprised that nobody suggested that. Even me!
