Where can I purchase Isspro tach R5503?
Postby Firstgenfanatic » Mon Jan 26, 2009 10:13 pm
Ok, I am ready to purchase my tachometer (Isspro R5503). Where can I buy it besides directly from Isspro? I also want mine with a WHITE needle. All the other companies sell them with the red needles. So......looking for R5503 with a white needle and under $170..........any advice?
*1993 Dodge Ram W250 club cab*, mild performance built A518, Hughes Converter, turned-up VE w/timing bump, tow package, 16x7 Alcoa wheels, M&H "M5" fuel pin, 366 gov spring, 4" exhaust, 16cm turbine housing, cold air intake, Isspro pyro/trans/tach/boost, KDP secured
Firstgenfanatic
Postby Richie O » Mon Jan 26, 2009 10:43 pm
Here you go.
http://www.egauges.com/vdo_ind.asp?Type ... R&PN=R5503
The description says red pointer but the picture shows white. I wanted to have a red pointer and called isspro's tech rep and he said they do not make the ev 4 k tach in a red pointer. I bought mine from Isspro directly. It was a white pointer. The tech guy has called me twice to see if I have it hooked up yet. I have bought 3 gauges from E Gauges.com and have had good service so far.
