Cigarette Lighter
Cigarette Lighter
Postby peobryant » Mon Feb 16, 2009 7:11 pm
I'm assuming this is an electrical problem. I tried plugging in my iPod charger into my cigarette lighter, and nothing happened. I wouldn't charge, so i tried my mothers GPS, and the same thing happened. I removed the night before about 3 pennys and a dime, that were stuck inside. Could that be the problem? Will I have to get a new one somewhere, or is it a fairly simple fix?
Thanks
Postby PToombs » Mon Feb 16, 2009 7:17 pm
Did you check the fuses? A penny will drop in the hole and pop the fuse. :shock:
Postby peobryant » Mon Feb 16, 2009 8:13 pm
PToombs wrote:Did you check the fuses? A penny will drop in the hole and pop the fuse. :shock:
I'll look into that tomorrow. Where would I get a new fuse? Anyone know the part number?
I guess I'll have to get all the change out of my ashtray...
Thanks Pete.
Postby KTA » Mon Feb 16, 2009 8:33 pm
Didn't you know? 1st gens are pre elctronic. When they were built there were no such things as ipods and gps systems. At least not that would fit in the cab. :evil: Such new fangled gizzmos have no business in the cab of a 1st gen!! When you clean the cab out with the garden hose(like all real trucks are done) what do you think is going to happen to those fancy gizzmos? I hear they don't like water. LOL It takes a standard atc type fuse available at wal-marts and parts stores everywhere. :P
Postby PToombs » Tue Feb 17, 2009 6:09 pm
What's a Gps ipod? Is that like the ABS box?
You can't buy fuses for these any more. I just keep switching mine from 1 hole to another. Radio in the daylight, lights at night, heater or wipers, etc. I can drive in the rain or the cold, but not both. Or I can have heat and wipers, but no lights. Really sucks! :cry:
Do you even know where the fuses are? :shock:
Postby Ace » Tue Feb 17, 2009 6:50 pm
I keep loose change in the ashtray, but I also keep the lighter plugged in. (don't smoke) 8)
Ace
Postby peobryant » Tue Feb 17, 2009 6:53 pm
Ace wrote:I keep loose change in the ashtray, but I also keep the lighter plugged in. (don't smoke) 8)
I don't smoke either, and the lighter was plugged in. I guess I forgot to plug it back in for a little bit, and when I did, the change was already in there.
Pete, you better be wrong.
Postby skilletky » Tue Feb 17, 2009 7:29 pm
i had this same problem. it drove me crazy!! i finally stopped putting change in the ash tray, problem solved. but you can still buy that type fuse. i keep a bunch in the truck,i still have a few wiring problems with the lights. if i knew you was having this problem i would have gave ya a bunch while you were up here.
skilletky
Postby peobryant » Tue Feb 17, 2009 7:58 pm
skilletky wrote:i had this same problem. it drove me crazy!! i finally stopped putting change in the ash tray, problem solved. but you can still buy that type fuse. i keep a bunch in the truck,i still have a few wiring problems with the lights. if i knew you was having this problem i would have gave ya a bunch while you were up here.
I didn't figure it out until I was on my way up, and I never even thought about a blown fuse. I tend to forget about those things. :oops:
I don't really need the lighter, but I like to have everything in my truck working properly. Although I've had a broken odo for a little over a year now...
Postby Begle1 » Tue Feb 17, 2009 10:02 pm
PToombs wrote:What's a Gps ipod? Is that like the ABS box?
Pete, what the heck are you talking about?
I have a GPS on a designated jack. I also have a laptop semi-permanently wired in to one of my two inverters and my aftermarket ECM. My head unit plays MP3 CD's and I have auxiliary 5 volt, 19 volt, pure 24 volt, nominal 24 volt, and 110 volt power supplies.
Postby Richie O » Tue Feb 17, 2009 10:18 pm
I just have 1 hot wire sticking out of the dash and I wire nut the accessorys that I need at the time. 8)
Postby Ace » Tue Feb 17, 2009 10:56 pm
Begle and Ritchie make a good voltage Yin-Yang! :P
Ace
Postby PToombs » Wed Feb 18, 2009 6:19 pm
Begle, just poking Parker a little. I can't let him get too comfortable! :lol:
Richie is a carpenter in his spare time. Just read his last post! ;)
Postby Richie O » Wed Feb 18, 2009 6:23 pm
That went way over my head. :?
Postby TWorline » Wed Feb 18, 2009 6:24 pm
:jumpsmile: That was great Pete! :jumpsmile:
Tim Worline
http://www.CoolerTubz.com/
TWorline
