Charging problem
Charging problem
Postby MudSlinger79 » Sun Apr 05, 2009 7:03 pm
Okay i cant get my truck to charge. I have bought 2 alts, a new external regulator and i cant get it to charge. The only thing i plan on trying tomorrow is running a wire strait from the battery to the regulator and see if that helps because right now im running it threw the chevy wiring. Any help would be appreciated thanks.
93 Ford, 1st Gen Cummins, 66/71/14 S-300, New Era 435 Sticks ,Pump Cranked, denny 2 fuel pin, afc MIA, 3200 spring. Sitting on 5 Ton Rockwells With 63" Rice And Canes. More To Come!!
MudSlinger79
Postby Philip » Sun Apr 05, 2009 8:10 pm
On that 79 the orginal wiring had one wire hot when the ignition switch was on. Take that to one field terminal. The regulator will go to the other field terminal. Make sure the regulator has a good ground.
If your using a aftermarket regulator take it back. Hit a junkyard and find an orginal Dodge regulator. Even a used one is better tham most aftermarkets ones are.
Postby MudSlinger79 » Sun Apr 05, 2009 8:53 pm
im running a new dodge regulator i am puzzled on this thing.
MudSlinger79
