The shiners...
The shiners...
Postby Oddfire » Tue Apr 07, 2009 1:26 pm
This morning when I was on my way home from work my high-beams went from their usual dull flicker to about twice as bright (only for about 1 sec.) and then back to dull. :sad: What the heck? :roll: Voltage reg. taking a sabbatical on me? My alt. showed about 2 volts of extra effort on the stock gauge the rest of the way home and didn't seem to change (about 2 miles). I would have screwed with it for a while, but tired in a dark driveway in a quiet neighborhood at 4am and a straight piped cummins isn’t the best idea. :lol:
Oddfire
Postby gear jammer 91" » Tue Apr 07, 2009 8:39 pm
The plugs on the back of my headlights will intermittently come loose. When one comes loose it will case the light to kinda flicker until I push it back on. I would check back there for a loose connection first.
01 LB7
gear jammer 91"
Postby Oddfire » Wed Apr 08, 2009 4:58 am
Na the dull flicker is there normal operation. :lol: The sudden voltage spike that caused the lights to suddenly get extremely bright is what has me concerned. :?
Oddfire
Postby Oddfire » Wed Apr 08, 2009 1:00 pm
I got a load of hay this morning and almost home, I drove past a lit burn barrel and smelled burnt plastic (got my attension). I looked down at my volt meter to see it paiged at 18+. :shock: 11:00am and not even the radio on! I was 1/4 mile frome home so I pulled in the driveway and shut her down, started back up and the gauge behaved. If I would have been thinking, I would have left it running and and chased the problem with a meter to see if the factory guage is screwin with me or not. :;-|:
Oddfire
Postby Richie O » Wed Apr 08, 2009 3:38 pm
I vote for voltage regulator.
Postby gear jammer 91" » Wed Apr 08, 2009 7:06 pm
I changed my mind, I think you need a voltage regulator, before your wiring harness melts down. :shock: Some of the regulators have been an issue before, but mine hasn't, so I don't know anything about what the problem is.
01 LB7
gear jammer 91"
Postby Oddfire » Thu Apr 09, 2009 5:19 am
Yah, as usual, it was the reg. :bh: :D :violin:
Oddfire
