PToombs wrote:I'd check the compressor. Either the clutch is shorting out or seizing, or the compressor is seizing.
Bad93Cummins wrote:Well don't think its the compressor or clutch casuse the air does blow and it blows pretty cool.
PToombs wrote:That's too low with or with out A/C. Should be about 800 or so. I'd have to check the manual to see exactly how it should be. Might be 750 or 800 in Drive with A/C on.
