fuel solenoid
fuel solenoid
Postby Gen 1/2 » Tue Sep 08, 2009 1:52 pm
I put a p pump on my 92 and wired thro the relay for the solenoid to pull up the plunger is on a push button but it just blow up my 2nd solenoid help
Gen 1/2
Postby PToombs » Tue Sep 08, 2009 5:33 pm
Sounds like you have it wired backwards. The pull in should come on with the starter and the relay should run the hold in. If the pull in coil is powered constantly it will melt it pretty quick. Double check the wiring and grounds.
Postby Gen 1/2 » Wed Sep 09, 2009 4:52 am
I have the on that releases it wired throw a push button maybe the buttons maybe bad
Gen 1/2
Postby PToombs » Wed Sep 09, 2009 6:40 pm
The push button should be the one to pull it in. Maybe the button is sticking on?
