Not sure wha tthe heck happened???????
Postby Bad93Cummins » Fri Sep 11, 2009 2:07 pm
Yesterday me and my dad wired up 2 of the 3 gagues I ordered(there add on's to the other gagues I just got and built a custom diamond plate gague mount)
Well we wired up both gagues and they both work(oil psi and water temp, gonna have my buddy do the tach so we don't fry the computer). Well we got them wired up and I went to work after getting them wired up, now my tranny gauge doesn't work, turn singls and brake lights don't work. The tranny is gague is the center gague on my pillar but the tother 2 gagues(boost and pyro) work still. The fuses are good and saw no wires disccounted, rubbing frame/metel and had power going to the fuses, so anyone know what might be the problem?
Thanks
Bad93Cummins
Postby KRB64 » Sat Sep 12, 2009 3:49 am
What did you tap into for power?
'92 W250 CC LE, auto, OD on shift, 3.54 limited; boost/PT pyro/tranny, oil temp, fuel press, tach; Bosch 190s, Ol' Smoky, 366 spring, full fuel, pull cable, 1/8" bump, synthetics, Borgeson, aFe, 16cm house, 4" pipe, AT cooler, ton shoes, ext reg...
KRB64
Postby Bad93Cummins » Sat Sep 12, 2009 6:17 am
Blue power wire located in fuse box.
Bad93Cummins
Postby cougar » Mon Sep 14, 2009 7:53 am
The blinkers and brakes are on separate circuits. The only thing they have in common is the turn signal switch. The connector comes off the column near the fuse box.
01 2500 "the work truck".
cougar
Postby Bad93Cummins » Mon Sep 14, 2009 4:19 pm
I got it all figured out now, got everthing working now. All gagues work now and all lights work now, thanks tho.
Bad93Cummins
