No Brake Lights
No Brake Lights
Postby Broncdiesel » Mon Sep 21, 2009 2:54 pm
My fuse for the brake lights blows instantly. I have looked and looked for a short to ground with no luck. I dissconnected the wires going to the tail lights and it still blows. So it seems to be under the dash or hood. Are there any problem areas I should look at? Thanks
Broncdiesel
Postby peobryant » Mon Sep 21, 2009 3:44 pm
Information on truck? Year, model?
Postby Broncdiesel » Mon Sep 21, 2009 7:17 pm
Truck is a 1990 D250 5 spd (cummins)
Broncdiesel
Postby cougar » Tue Sep 22, 2009 9:05 am
Pull the connector that comes off the steering wheel. That will isolate the wiring from the fuse to just before the blinker switch.
01 2500 "the work truck".
cougar
Postby gear jammer 91" » Fri Sep 25, 2009 8:08 pm
If your truck is wired for trailer lights I would start there. I've had this problem on two trucks, and in both cases the short was in the trailer light wiring.
01 LB7
gear jammer 91"
