Odometer/Tripometer dead
Postby Rudan » Tue Oct 06, 2009 9:54 am
Anybody know where to get an aftermarket speedo that will work on a 92
d-250? My speedo works but the odometer is gone. Is it even worth while to try to find salvaged unit? I think you will eventually run into the same problem as this one. I hear a gps unit will work, but would rather have the meter.
92 D250 ClubCab longW/B 5-speed getrag Bone Stock..Wife's Rig 2006 Dodge 1500 "Lone Star" gasser.
Rudan
Postby RumbleFish » Tue Oct 06, 2009 12:14 pm
sounds like you need the drive gear inside the cluster. its not a hard fix.i dont remember for sure where to get the parts, i think maybe philip knows. the gear is a bit pricey, but still cheaper than an aftermarket gauge.
Postby Rudan » Tue Oct 06, 2009 1:05 pm
Thanks..I saw some blogging about that the other day. Some one said everything went good until the 10th's counter went to 1, and then it quit. They thought maybe the gears stripped again. Plastic in this dash is soooo
fragile. Anyhow, maybe Philip will chime in..Thanks again
Rudan
Postby peobryant » Tue Oct 06, 2009 11:44 pm
This link shows you how to replace the gears. It also has a link to a site where you can buy the gears.
http://www.dieseltruckresource.com/dev/ ... l?t=128685
Apparently, you can also use the odo gears from '90's model Ram vans as well... Much cheaper than the other option.
http://www.dieseltruckresource.com/dev/ ... l?t=185945
Postby Rudan » Wed Oct 07, 2009 7:16 am
Gentlemen....Thanks so much, very helpful information. I look forward to returning the favor..Rudan
Rudan
