by Mark Nixon » Wed Oct 07, 2009 8:00 pm
Blue wire on the pump solenoid on the injection pump to activate fuel, run a lead from there to the battery positive.
Then, to activate the starter, undo the 2 pin plug just off the battery, the one with the brown and pink wires.
On th lead NOT conncted to the battery, the brown wire is solenoid direct to the starter, create a lead and touch it to the positive on the battery and she should fire up.
One thing though, I'm wondering WHY the ignition switch is fried?
