need to know wat lead wire to get
Postby james-93-12valve » Tue Oct 13, 2009 5:37 pm
here is the pyro
here is the thermocouple
93 d350 5spd 4inch exhaust to a 6inch tip pump tweaked
james-93-12valve
here are the compatable
Postby james-93-12valve » Tue Oct 13, 2009 8:50 pm
james-93-12valve
Postby james-93-12valve » Wed Oct 14, 2009 12:58 pm
bump.............
james-93-12valve
Postby Ace » Thu Oct 15, 2009 5:24 am
Seems there was a thread about pyros a few weeks ago where the consensus was any old lead wire will do.
Where's all the experts when you need them!? :lol:
Ace
Postby Begle1 » Thu Oct 15, 2009 8:09 am
The wire that you get depends on how much distance you have between the probe and the gauge.
Call ISSPRO to be sure.
Postby Ace » Thu Oct 15, 2009 11:08 am
Some of those ISSPRO's need a seperate amp module.
Ace
Postby james-93-12valve » Thu Oct 15, 2009 6:25 pm
stupid question but if i just cut and spice an difrent lead wire together would that work im cinda low on money right now and i have a lead wire off an old pete thats still in the box
james-93-12valve
Postby dpuckett » Sat Oct 17, 2009 6:23 pm
James, just strip the end of the insulation back, hook the copper wire around the terminal on the gauge and run it til you get some cash. I've done it before, and as long as your connections are tight, all will be well. I've also run a 6ft lead wire that I bought locally, and it worked as well. Actually, the one from the Peterbilt should work, too. It seems they are just copper wire anyway.
Ace- The EV series gauges need the amplifier. As long as the gauge is flat faced (this one appears to be), you just need the lead wire. Good point, though.
Dan
Postby james-93-12valve » Sun Oct 18, 2009 7:41 pm
thank you everyone
james-93-12valve
