The first question is about the speedometer. The truck I bought came with a broken odometer. The speedometer worked, but the odometer didn't. Mark sent me another used one to replace it with, but now in addition to the odometer not working, the speedometer will not go past 55 mph.
Order of events.
Replaced gauge = odometer still not working.
Replaced vss with a new one = odometer still not working.
(I don't recall if the speedo only went up to 55 mph before the vss or after.)
I'm drawing a blank on what is causing this. Loose wire? Does the signal from the vss run through the computer? Suggestions?
Second question: where is the coolant temp sensor located? Is it the one in the middle of the block, behind and below the injection pump?
Thanks guys.
