Toggle switch for overdrive
Postby 92 D/UNIT » Wed Nov 25, 2009 8:37 pm
I was wondering if anyone had any info on how to wire in a toggle switch to keep the 518 from downshifting into Drive while dynoing? where are the wires and what color do i tap into?
388/886
92 D/UNIT
Postby IowaCummins » Thu Nov 26, 2009 2:31 am
search for the replacement potentiometer or "pot" that we use for over trive control instead of the tps. i hvae done it and love it. you can also use that thread to figure out what wires to use.
IowaCummins
Postby cougar » Thu Nov 26, 2009 8:56 am
01 2500 "the work truck".
cougar
Postby 92 D/UNIT » Thu Nov 26, 2009 7:51 pm
thanks for the info, I was trying to figure out how to just hook up a toggle to keep it from downshifting into drive while leaving the stock TPS in place. im not even sure if it can be done.
388/886
92 D/UNIT
Return to Electrical
