dpuckett wrote:I had a truck that had some copper ends on the cables, then marine terminals on the battery. Wing nuts holds the ring on the battery, no more broken lead cable ends. Also makes adding accessories easier- undo the wing nut, add the ring from your wire, tighten wing nut.
Dan
