PCM question
PCM question
Postby cumminsfreak86 » Mon Dec 21, 2009 11:44 am
I am having a voltage regulator problem (flashing lights). Heres my situation, I have replaced the alternator and bought two new regulators to replace the old regulator which I believe was causing the battery to overcharge. Just on a hunch I completely unhooked the wire to the new regulator (essentially an open circuit) and did a voltage test. I then hooked up the new regulators and performed the same test. They put out the same exact voltage reading. I wonder how this is possible when the old regulator is causing the battery to overcharge? Because of this, I don't think it is a connectivity issue between the regulator and the battery.
I have a theory that the PCM has been replaced by a previous owner because the wiring does not look factory. My big question is:
Is it possible that the PCM that is currently in the truck can not communicate with the new regulators I bought for my 91.5 year model truck? In other words, if there is a PCM from a certain year model truck (say a 89-90 or 92-93) and I had a regulator for a 91.5 truck, would the PCM not be able to communicate properly with the new regulators I have now?
This is the only possibility I can think of. I am truly sorry for the book. I just wanted to make sure I provided adequate information.
Thanks,
Chris
91.5 W-250 RCLB 5spd. 6" lift. some go fast parts.
cumminsfreak86
Postby Ace » Mon Dec 21, 2009 11:55 am
Do you mean that with the engine running it makes around 14v with the external regulator connected or not?
Ace
Postby cumminsfreak86 » Mon Dec 21, 2009 11:56 am
Yes, all my readings are taken with the engine running at idle. The new regulator makes 12.5 volts when hooked up. With the new regulator unhooked completely, I am reading 12.5 volts also. I read around 15 volts with the old regulator hooked up but that value fluctuates.
cumminsfreak86
Postby Ace » Mon Dec 21, 2009 12:12 pm
It should make more like 14v if it's charging.
Ace
Postby cumminsfreak86 » Mon Dec 21, 2009 12:17 pm
Yeah I thought so which is what gets me confused. I originally thought I just got a bad regulator the first time I tried to replace it because it wasn't charging. I then went and bought another regulator and the exact same thingtoo place. This is what led me the come up with the question/theory in my original post.
cumminsfreak86
Postby cougar » Thu Dec 24, 2009 9:03 am
The regulator controls the field winding to ground. With the regulator disconnected, you should see only battery voltage. I would suspect a bad ground or connection to the regulator if the voltage is dropping. I would suspect the wire to the regulator is shorting to ground if the voltage was going up.
01 2500 "the work truck".
cougar
Postby cumminsfreak86 » Fri Dec 25, 2009 12:47 pm
Hmmm. I didn't think about that for some reason. I'll have to check it. Thanks man.
Chris
cumminsfreak86
