speedometer dead
speedometer dead
Postby 1dumrednek » Mon Dec 28, 2009 6:03 pm
i recently put a new clutch and rebuilt the tranny. ever since i put it back together, the speedometer doesnt work. the cconnector is hooked up. until last week it wouldnt move at all and now ita has started to twitch erratically. ive seen it hit 180 kmh and the truck wasnt moving :shock: i unplugged the connector on the transfer case and it stopped twitching. where do i start?
A.J.
91.5 Power Ram w250 LE 5spd reg cab... totalled... again
2002 2500 laramie slt plus sport, nv5600, MBRP 4" straight pipe, edge juice w/ attitude, DC1 rims, kelly fierce attitude M/T
1dumrednek
Postby lectro_static » Mon Dec 28, 2009 6:23 pm
sounds like a grounding issue to me check that you have your ground straps on and CLEAN along with the area it bolts to
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby 1dumrednek » Mon Dec 28, 2009 8:05 pm
which ground? i dont remember unhooking any grounds when we pulled the tranny. or is it a different ground?
A.J.
1dumrednek
Postby oldestof11 » Tue Dec 29, 2009 4:01 am
Check the ground at the engine. The tranny might have been used as the grounding "strap" for the engine. Then again, other things would be acting up too....
