what do you guys think of this tach?
Postby redneckroot » Fri Jan 15, 2010 5:44 pm
I just wanted to know what you guys think of this tach? http://www.summitracing.com/parts/ATM-3788/
redneckroot
Postby oldestof11 » Fri Jan 15, 2010 6:11 pm
Do you plan on going past 5k?
I like it!
Postby Jim Leap » Fri Jan 15, 2010 7:20 pm
I like it. I'm just not sure about the calibration issue since it is picking up the signal from the alternator. Seems like you would need a crank tach to calibrate it.
Jim
1991 Ram 250, 4X4, regular cab, 5 speed
Jim Leap
Postby Richie O » Fri Jan 15, 2010 7:21 pm
Jim Leap wrote:I like it. I'm just not sure about the calibration issue since it is picking up the signal from the alternator. Seems like you would need a crank tach to calibrate it.
Yup, photo tach is the best way.
Postby PToombs » Fri Jan 15, 2010 7:24 pm
No reason that won't work. I would use a photo tach to make sure it's right or to set it also. I'm sure there's a way to calibrate it once it's mounted.
Postby redneckroot » Fri Jan 15, 2010 8:35 pm
I just thought it looked good, and should hook up easy. I have a hand held tach to shoot the crank with. Now if I only had the money.....
redneckroot
Postby CAJUN 93 » Sat Jan 16, 2010 7:36 am
i've had the black version in my truck for several years now. works great. i used the drb 1 at the dealership to calibrate it. any optical tach will work for comparison. mine was off about 100 rpm across the board. neat thing was once it was calibrated, it was dead on match with the drb at idle and 2600 rpm and everything in between. good product.
btw, member here tomtom has that same silver tach in his and i dont think he's had any problems either
daryl
CAJUN 93
Postby ccoxva » Sat Jan 16, 2010 3:30 pm
Have had mine about 5years never a prob. Good tach
1991 N/I 250
1996 Dodge 3500 Ex. Cab Dually 19.5's
ccoxva
Postby doublel89 » Mon Jan 18, 2010 5:36 pm
I've got the black style of this one. I used math, or the free internet calculator, where you enter in what your diff and trans gear ratio is, and tire size, it told me the rpm's i should be running at 55. test drove the truck locked up in 3rd, and calibrated it to my spec. has worked good ever since, looks real nice with a red LED light
91 3/4 Ton 4x4, 5.9 Cummins,DDP Fuel Pin I usually leave it out though, DDP 40 Horse Sticks, HX35W And 2nd Gen Intercooler, Single 5'' Trunout, NV5600 Swap, Dually Conversion, 3.08 Rear Gears, Soon A Custom Hauler Bed
doublel89
