cruise trouble shooting
Postby rook440 » Wed Jan 27, 2010 10:45 pm
How and where do I begin trouble shooting my cruise control on my 92 cummins ,and where do I find info on this ,,It never worked when I bought the truck so I dont know where to look or what it was doing when it quit ...thanks rook
rook440
Postby lectro_static » Wed Jan 27, 2010 11:26 pm
Mine works most the time but blows the fuse alot, Im guessing I have a short either in the switch or the column.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby ccoxva » Thu Jan 28, 2010 5:53 am
My 91 dont work either but dont see how it could if it were fixed as sloppy as the converters are in therse things??
1991 N/I 250
ccoxva
Postby GO OVRIT » Thu Jan 28, 2010 5:07 pm
I've had the clockspring go bad in a 92 and 93. You can check continuity through it with a multi-meter. Of course I'd check the easier stuff first, like the brake switch, clutch switch if manual and the fuse panel. Does the speedo work?
GO OVRIT
Postby M37 » Fri Jan 29, 2010 6:48 pm
I have trouble with mine, just bought the truck. I tried the cruise, didn't work, flipped the accel/decel button a few times, it started to work, kicked off on the first hill, now cant get it to work again. Sure would be nice to have trouble shooting manual
M37
Postby rebel horseman » Sat Jan 30, 2010 8:22 pm
My 93's didn't work when I bought the truck, but a few weeks later I tried it and it started working again. It's a random problem that I'm pretty certain is the clock spring.
'93 Ram D350 Club Cab, ETC, G360, 366 spring, fuel screw screwed, star wheel bottomed, smoke screw flush, BHAF, straight pipe, DennyT Stage II pin. 182k miles.
rebel horseman
Postby M37 » Sun Jan 31, 2010 7:25 am
What is the clockspring ?
M37
Postby rebel horseman » Sun Jan 31, 2010 8:59 am
The clock spring is in the steering column. It's what allows the wires to pass through the rotating area of the steering wheel. It requires pulling the steering wheel in order to change it and is a common failure in these older trucks.
rebel horseman
Postby 1STGENFARMBOY » Fri Feb 05, 2010 12:41 pm
Ok i hope you don't consider this a hijack,but i have no cruse either so i pulled the centercap checked the buttons and continuity,and my horn does work fueses are good spedo works brake switch is good, now what. :roll:
Postby M37 » Fri Feb 05, 2010 2:00 pm
No problem, any interest helps the cause. I wish we could get a wiring diagram posted, it would help knowing how the circuit is routed for troubleshooting. I checked my fuses and haven't got to pulling the wheel apart... I kind of thought the fues box is the worse design ever
M37
Postby diesel freak01 » Fri Feb 05, 2010 2:17 pm
someone give me an email i cant post pics at work but i will email it when i find it
1993 d350 ctd drw 2wd auto
diesel freak01
Postby M37 » Fri Feb 05, 2010 4:06 pm
my email is jam0000@yahoo.com
M37
Return to Electrical
