To those of you who have one, is it super slow to respond? I got one used at what I thought was a good deal, but after hooking my boost guage in place of it yesterday, I'm beginning to wonder. The ISSPRO gauge takes at least 3-4minutes to get to 7-8psi (which is what my cheapo boost gauge says my Lucas piston pump puts out- adequate for my near stock engine), sometimes longer. It seems worse when cold. I was wondering if this is normal for the ISSPRO mechanical fuel pressure gauges, or if mine is defective? I have a snubber in line, hooked up to the banjo bolt post-filter. Turns out the gauge also has a restrictor built into it as well, so I am almost positive the pulsing of the pump(s) hasnt killed it.
Dan
